Results 1 to 10 of 11
Thread: Dash clock messages?
    Default Dash clock messages?
    Hi, I am new here and this site is amazing especially for the owner of an E34 525i.
    Just a quick question?
    How do people get the part of the E34 dash which displays the warning messages to display other stuff like the time and speed and other stuff?
    I have seen a few like this now but have no idea how it is done or what it can actually display other than the error/warning messages.
    Here is an example of what I mean.
    Press the turn signal stalk to scroll through the various functions.
    It can also be customized to display only desired information.
    Search OBC and unlock OBC for more info.
    It is all mentioned in the owners manual.
    If you do not have one, it is available online, just use the search here.
    Thanks for the help Ross and Paul in NZ, I never even realised my indicator stalk even pressed in, thats great.
    And thanks shogun for telling me to search for the owners manual, not really an answer I was looking for but thanks for taking the time to post a reply.
    Wellington,New Zealand
    each press of the end of the stalk will advance through the obs functions one by one.If you press and hold for a time(a few seconds) you get prog or similar,you can then press the buttons on the obc each press will program the custer to display that function...when you have pressed as many functions as you want to display you press the end of the stalk again...you can program as many or as few functions to display as you like.some buttons on the obc have two functions,ie the clock displays on the first press of the clock and the date displays on the second,cinsumption 1 on the first press of consumption,consumption 2 displays on the second...
    Sep 2007
    Seattle, WA
    Didn't know you could 'program' which info comes up or not.
    Will have to play with that a bit as I hardly use most of it. And it'd be nice not to scroll through so much of it...
    Quote Originally Posted by bubba966
    I think I have time range consumption temp....if a road trip is looming i might add arrive,and distance
    Marietta, GA
    Hold the stalk in for three seconds then press the buttons on the OBC for the info you want to be displayed. Then I think you hit the S/R button, maybe just press the stalk in again and it saves it.
    edit:
    Check out this PDF, should tell you pretty much all you want to know.
    Jan 2008
    Sweden
    Of course u need the OBC IV and fitting blinker stalk to do all this..
    Iīm writing this coz I donīt have it as many others
    Feb 2008
    Wausau, WI
    The only annoying thing is that the slightest warning message, like "Low Washer Fluid" prevents anything else from being displayed. You *have* to fill your washer fluid if you want to know what time it is.
    Pat Washburn
    Wausau, WI
    1995 525iT
  1. error messages
    By compmore in forum 5 Series BMW
    Last Post: 05-18-2009, 05:14 PM
  2. Help with dash check control messages?
    Last Post: 10-01-2007, 05:27 AM
  3. Help: Error messages
    By Al Gray in forum 5 Series BMW
    Last Post: 09-03-2007, 09:13 PM
  4. Translation of messages...
    By Muratti in forum 5 Series BMW
    Last Post: 03-10-2004, 01:06 AM
