I'd recommend joining the bmwcca for discounts on heavy lifting- like engine mounts and gaskets.
Sunroof is nice & sound and no eveidence of leaking anywhere. When I looked at the car last night and opened up the door, the small of fresh leather was there. The interior is perfect except for a small crack in the wood by the shifter and the small insert fo the gear selector is missing. Scoped out the body and under the green algae is a nice shiney paint job and nice pinstriping. It's very red. Car looks like it was well taken care of. Owners always had is serviced and it looks like it was done before it was parked. Hoses and belts look new. The door hinges are well sprayed with lithium and looks like it was done so on a regular basis. Initial inspection of the brakes looks like some minor surface rust on the rotors but. Underside has no rust.
One problem is that the tires do not hold air. It's either they are shot or the small crappy camping air pump I was using could not pump it up. I will be going back with the compressor in the back of my truck and see if I can get them filled. I only need to have them hold air long enough to get on & off the hauler.
What's an ICV?
