Problems bleeding the clutch slave Cyl..
I flushed my brakes a while back with no problems, and just got around to do the clutch slave today.
There is no problem at all with the function the clutch.
I tried to vacuum flush it first with a Mity-vac with the catch reservoir........Nothing........Tried with a helper pumping and holding petal..... Very Slight dribble.........Then tried pressurizing the master Cyl. reservoir........Nothing.
Finally gave up and cracked the hard line to the slave and pushed up and down on the rubber hose to slave hard line ........got a nice stream doing that, felt like I was milking a cow down there !!
Anyway what do you all thing the problem is ?
Slave about to take a ****, or is my bleeding technique all wrong ?
1991 525i M50 5 Sp.
N.California
