I've removed the plate on top of the steering column, the one with the two anti theft bolts, but now I don't know how to remove the steering lock itself. I see no way to continue the removal process. There's nothing under the plate, very weird, the plate doesn't even seem to be necessary.
This is essentially a continuation of a previous thread where you all, and especially Bubba helped diagnose a no-start condition on my Nieces 1995 525ia. I got the car started by removing the ignition switch, and manually turning it with a large slotted screw driver.
I dremeled slots in the the anitheft bolts, but they would not budge. I ended up dremelling the whole head off the bolt. The top plate is off the steering column, but the steering is still locked. So I can drive the car, but only straight.![]()
