Results 1 to 7 of 7
Thread: Vacuum Hose to the FPR
    Do a stomp test to see what codes it might have as a starting point.
    Bellevue WA
    86 Porsche 951 - Track Toy
    Good work.
    There are two 3mm vacuum hose lines that connect under the intake manifold. Hose one is your FPR hose; hose two is the one that T's off the valve cover vent.
    If you feel under the base of the intake manifold just behind the block to manifold brace you should find where they connect. If you had a mirror and light, you might be able to see them.
    Can't recall for sure, but you may need to disconnect the fuel hard line mounting bolt at the base of the manifold to make a little extra room. Been a while since I've had to deal with these.
    Bellevue WA
  1. vacuum hose
    By dolfan13 in forum 5 Series BMW
    Last Post: 12-16-2006, 09:53 PM
  2. Trying to ID vacuum hose part #s
    By blee in forum 5 Series BMW
    Last Post: 08-28-2006, 03:47 AM
  3. M60 Brake Vacuum Hose
    By MBXB in forum 5 Series BMW
    Last Post: 12-29-2005, 04:08 PM
  4. What's the vacuum hose under dash?
    By grr in forum 5 Series BMW
    Last Post: 12-15-2004, 01:53 AM
  5. m30 vacuum hose question.
    By BMW-F1-FAN in forum 5 Series BMW
    Last Post: 03-28-2004, 02:29 PM
