Results 1 to 10 of 14
Thread: Thrust Arm Install (I know, I know...)
    Dec 2005
    Nashville, TN
    Default Thrust Arm Install (I know, I know...)
    ...this has been discussed a zillion times, and I have read every thread / resource / website I can find, and I'm still stuck on the install. Specifically - getting the ball joints out with a tie rod puller ended up working quite nicely. Getting the new ones in, not so much. The self-locking nut starts to grab pretty early and the ball joint just spins in place, no joy. I'm trying to get my head around these instructions:
    "5. If the ball joint turns while tightening the nut, use vice grips or pliers to hold the bottom of the ball joint to the steering plate."
    Huh?
    Can someone please enlighten me, or recommend an alternative procedure? Everything else is done.
    Oh, and these are Lemforders from BMA. Thanks in advance, all.
    -Zak-
    1995 525iM - 131k - Alternator play, broken s-belt
    1995 525iA - 147k - Tensioner weirdness, broken s-belt
    2001 Intgra GS-R - 130k - spun bearing
    2002 Honda Odyssey - 80k - fragged transmission
    Do you have access to a cordless or corded impact gun?? Thats the easiest solution. If not, try tapping on it with a hammer to get it started.
    Dave
    Mar 2007
    Liverpool UK
    I'd question the part - I've done my thrust and control arms and none spun on tightening - they should be tight shouldn't they? If not a big G-clamp might work if you can tighten it enough...
    Dec 2005
    Nashville, TN
    I hear ya, but both parts (L & R) were identical... I'm going to get under there tomorrow morning and see if I can get a clamp on it. Thanks!
    Dec 2005
    Mt. Vernon Ohio
    Quote Originally Posted by ProZak
    I'm not sure what you mean but the L & R thrust arms are not the same!!! Trust me!! OMG!
    1993 525iA M50TU
    Black on Black...need pics
    208,888 miles
    I've had new Lemforders want to spin. New nylox lock nuts are sticky buggers and grab at the ball joint pretty tight. Agree, a clamp should work to get the taper started on the steering arm.
    Dave
    Dec 2005
    Nashville, TN
    Dave
    Fraid not. I didn't bang on it at all, didn't want to mess up the joint.
    Maybe I can get a clamp in there. Thanks for chiming in so quickly.
    Well, you got through the hard part (getting the ball joints out).
    Anyway, I'd try to somehow clamp the two pieces together to get a bit of friction on them. Possibly use a large C clamp? Not really sure how I would suggest clamping them together. Maybe have a friend put some downward force on the thrust arm while you tighten the nut?
    Like it was mentioned before, the best way would be with an impact gun.
    man I go away for a while and you guys forget everything I taught you! lol... use a old a metric nut without the crimp or nylock to set it tight, then come back with the locking nut and torque it in.
    Mar 2007
    Liverpool UK
    Tricks of the trade - I like it!
  1. Thrust Arm Q
    By RallyD in forum 5 Series BMW
    Last Post: 03-31-2007, 08:15 PM
  2. Thrust Arm
    Last Post: 11-23-2005, 03:38 PM
  3. Replacing thrust arms vs. thrust arm bushings
    Last Post: 05-09-2005, 08:08 AM
  4. Thrust Arm Q's
    By nealf in forum 5 Series BMW
    Last Post: 07-29-2004, 06:42 PM
