Results 1 to 7 of 7
Thread: Plastic ring that goes under the wheel
    Wellington,New Zealand
    doesnt explain pulling to the left,,and that tyre is toast,you can get way without rings in the rear but only if the wheels are evenly torqued.The car will feel strange until the tyres "bed in" to their new position.But you must change the tyre with the bulge in it!
    Gone but not forgotten
    Aug 2005
    Default Plastic ring that goes under the wheel
    I went to check the balance on my wheels. It turned out the front left wheel developed a small "bulge" on one of its vertical sides (not the one that faces the road). I didn't have a new tire, so he rotated the front left and the rear left. It also turned out a small plastic ring that sits between the wheel hub and the wheel disc on rear left wheel had been trashed. It seems like the last time they weren't installed correctly and the wheel tightened on top of them. They looked like if they were put under a press. He threw it out and installed rear wheels without it. Said these weren't really necessary.
    Hopefully tomorrow I will change both rear wheels. However, at the moment car keeps pooling to the left. Tire pressures are all the same. I didn't have this before. Does that ring really unnecessary?
    wheels are 225-16R-55
    VIN: GG45422
    I can hear the next question - "Why is my car vibrating?"
    Obviously you don't have oem wheels on your car. Get them put in again!
    Search for hubcentric rings.
    Greg
    E30 318iS & BMW K1200LT
    Oldham, England
    Default Tyre problems
    Had a problem with one of my cars pulling to left and could never find the problem - till I got a puncture and the tyre was replaced. No more pulling! Surprised a mechanic would agree to putting a duff tyre back on
    Mar 2007
    Liverpool UK
    Quote Originally Posted by t_marat
    You want to get metal Hub rings, I had the same problems with the plastic ones they're sh*te. Get aluminum ones and you won't look back.
    1995 XJR: 4.0L S/charged straight 6 Auto
    What... It's not broken??? I can still fix it
    with the aluminum ones make sure you use antiseize or youll wish you got plastic.
    Quote Originally Posted by e34.535i.sport
    Mar 2007
    Liverpool UK
    I throw the copper stuff on most things these days luckily Jeff!!!
  1. Shifter boot with a weird plastic ring
    Last Post: 09-01-2007, 05:10 PM
  2. Interesting vid of M5 at the ring
    By Anton CH. in forum 5 Series BMW
    Last Post: 01-28-2007, 02:52 AM
  3. Ring, ring
    By GJPinAU in forum 5 Series BMW
    Last Post: 11-03-2005, 12:28 AM
  4. hubcentric ring for E39 wheel to go on my E34?
    By pismojeff in forum 5 Series BMW
    Last Post: 12-18-2004, 04:44 PM
