Forget line locks, unless you use solenoids as Winfred sez.The lines make it bloody difficult unless you re-run the lot which is the only real option.If you have single piston front callipers then REXROTH make a solenoid which will work(Case-poclain/cat control valve) but requires 8 amps to hold and 22 to pull in. Can give numbers if you PM me.
