Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: M60 rough idle
    Mar 2008
    Default M60 rough idle
    I just purchased a 540i auto, my second e34. I got a rough history of the car, but very few records so it is hard to tell what has been maintained.
    I have done a search through the threads and have some ideas about what might be the cause of the problem, but wanted to get an idea of what to do first.
    The problem: heavy vibrations at idle, O2 sensor code.
    My question: What are some good ways to diagnose this without running out and buying a bunch of expensive parts?
    so far I have taken the covers off to check for oil around the plugs. There was just a small amount toward the rear. The rest looks dry. I guess I should take the plugs out to see how they look. I believe they were replaced within the last few years / 40k miles but theres no way to know for sure.
    I'd like to check for leaks. Does anyone have a diagram or can explain where to look for vacuum leaks?
    Thanks in advance.
    almost certainly it's the pcv plate on the back of the intake, you can squirt around the intake with carb cleaner and see if the idle changes, slim chance it's crappy plugs or a failing maf but if it runs good other wise it's probably not a maf, we just had a couple threads on doing the intake job and someone will probably post them up if you can't find them
    Nov 2006
    central coast nsw
    check your intake gaskets.i also had a rough idle and did plugs o2 sensors etc but still had probs.since i had the intake gaskets done in now idles and runs
    like a dream.
    good luck
    geoff
    Tampa Bay, Florida, USA
    Search for Gearhead's post from last week.
    Ramon
    1994 540iA Nikasil EAT Chip
    Tampa Bay, Florida USA
    Agreed
    So Winfred... you said "what snow?" Guess you should have kept your mouth shut... LOL. I heard there was a massive whiteout at Flagstaff, AZ that caused a massive Highway 40 accident.
    SCHUYLKILL COUNTY, PA.
    Default i had the same thing with my 540i/a when i bought it.......
    it turned out the cats were blocked shut.
    i found this out after replacing the intake gaskets, pvc plate, & 02 sensors.
    tim s.
    huh?! i am in loserana so bring it on i dare it to snow
    Mmmm... Maybe I got you mixed up with BillR... since when did you live in Lousiana?
  1. Very rough idle, 92 525
    By aecs8284 in forum 5 Series BMW
    Last Post: 06-20-2008, 11:07 AM
  2. Rough Idle
    By hinchcliffe in forum 5 Series BMW
    Last Post: 08-27-2006, 10:12 PM
  3. Rough Idle....???
    Last Post: 04-06-2005, 02:51 PM
  4. Rough Idle
    Last Post: 06-25-2004, 12:59 AM
  5. Rough Idle
    By Will308 in forum 5 Series BMW
    Last Post: 02-21-2004, 03:34 PM
