Results 1 to 3 of 3
Thread: Horn probs
    Default Horn probs
    hey guys, got abit of a problem with the horn on my 89 520i, I push the horn pad on the steering wheel and nothing happens so i decided to try and investigate, Ist i linked pins 30 and 87 of the horn relay to see if the horn(s) would sound and they didn't, so i took the relay out and checked to see if there was any voltage going to the horn relay and there is over 12 volts going to the horn relay, next i checked to see if there was any voltage at the horn connectors so i took out the connectors that plug into the horn(s) to see if there was any voltage going to the connectors and there was but it was only about 1 volt or so. Does anybody have any idea's as to what could be the problem? and how to fix it?
    Thanks guys
    Fraser
    There must be corrosion in the wire between the horn and the relay. Probe the wire back from the plug to the horn, the rot usually occurs near the teminations.
    I don't know if you used the horn connector for ground also when testing but a poor ground, err earth, could also be the issue.
    Just a quick update on the problem im having with the horn(s) i checked the fuse today and checked to see if there was any voltage going to the fuse and there is 12 volts goin to the fuse, also i took another voltage reading from both the horn connectors this time with a better earth and i got 11.6 volts at the left horn connector and 9 volts at the right horn connector, i then put a direct 12 volt supply to each of the horns using a fully charged 12volt car battery and neither of them sounded. has anybody any idea's what the problem could be?
    thanks guys
    Fraser
  1. horn
    By Fraz06 in forum 5 Series BMW
    Last Post: 03-06-2007, 03:15 PM
  2. horn probs
    Last Post: 01-24-2007, 06:39 PM
  3. horn
    Last Post: 01-03-2007, 03:46 AM
  4. Horn
    By Torque in forum 5 Series BMW
    Last Post: 11-20-2004, 09:01 AM
  5. Horn help
    By PatrickPGH in forum 5 Series BMW
    Last Post: 11-08-2004, 03:10 PM
