Clutch Master Cylinder
I replaced a failed slave cylinder the other night without too much difficulty, other than not realizing at first the drain from the brake reservoir is near the top and I filled the system with air. Took awile to clear the system, but now works great again.
I also ordered a replacment master and have to admit after seaching here and fiddling under the car and removing the bolts on the master.....How the %&#* do you get the fluid lines off this thing. The main feed from the resevoir I am going to remove from the reservoir and just pull through the firewall. Good idea or bad idea?
What is the trick to getting the metal fitting disconnected from the master unit when you can't see the damn thing and have to be a contortionist to even get you hand on the fitting???? Any help is appreciated...
94 E34 525i M50, Manual, 200,000 Miles
02 E39 530i M54, Auto, 85,000 Miles
