Results 1 to 10 of 13
Thread: AC compressor / replacement
    Aug 2004
    Dubai
    Default AC compressor / replacement
    few months ago there was floods and heavy rain, and after that the AC compressor stopped compressing as I took it to a repair shop thinking that the gas is out. but the compressor was dead.
    I was wondering if I can fit in the E38 compressor in? does it have the same brackets? Thanks
    your compressor is probably the same as on the E32 750. Check on realoem, and also check which brand is actually installed on yours.
    Here is a repair info on Nippon Denso
    http://www.pelicanparts.com/techarti...so_rebuild.htm
    http://www.a-aironline.com/bmw.aspx
    Aug 2004
    Dubai
    I thought it was Seiko?
    Aug 2004
    Dubai
    http://www.a-aironline.com/detail.aspx?ID=258 this is the one, same as the E38 unto 1996.
    final question, the low compression rate is only due to a bad compressor or there might be other causes? just in case the technician doesn't know what he's doing
    The system is completely closed system under pressure and no water can enter.
    I assume that there is/was a short in the wiring system or some wires/connectors are corroded. That I would check first on the compressor.
    Something what is electric...... and can be damaged with water or by a flood.
    Aug 2004
    Dubai
    well the compressor is getting the signal and I can hear the hissing of the gas getting into the system, but when I took it thining that the gas leaked out, the technician said that the compressor was very weak
    Tampa Bay, Florida, USA
    Try checking the refrigerant pressure and seeing it if is within spec? Check for leaks first.
    Ramon
    1994 540iA Nikasil EAT Chip
    Tampa Bay, Florida USA
    Aug 2004
    Dubai
    pressure is right, but when the AC is on the compressor doesn't show enough pressure. for sure no enough cooling, inside the car I can hear the gas hissing in the system, without any cold air.
    I
    I am not an aircon expert, but that would make me nervous. Hissing...
    for me, as amateur,....
    not enough gas inside.
    one more
    you say
    pressure is right
    how did you check this, any test data?
  1. A/C compressor replacement on a 89 525i
    Last Post: 06-10-2004, 02:07 AM
  2. where to find replacement compressor?
    By carolina525 in forum 5 Series BMW
    Last Post: 05-22-2004, 11:06 AM
  3. A/C Compressor replacement.....Bill?
    By callen in forum 5 Series BMW
    Last Post: 05-04-2004, 07:00 PM
  4. Replies: 3
    Last Post: 04-12-2004, 10:28 AM
  5. A/C compressor replacement
    By SlowPokey in forum 5 Series BMW
    Last Post: 03-29-2004, 10:07 AM
