Moly-Graphite lube is exactly Molybdenum. I don't know about your exact ratio specs but we use 20-25% on most of our plastic bearings.
You can't go wrong with Lubro Moly product... they do have moly grease tube... Maybe Zygmunt has them in stock for you.
Is it just "moly" lube? But I have read that "moly" has different ratios of "moly" anywhere from 3% to 65% and such. This is really minor - its for the nylon cup bearing on the ball of the shift handle, I just want to do it right and not have to worry about replacing it any time soon.
Thanks all
Might be the same stuff I use. Langzeit just means long-lasting.Originally Posted by Jon K
Anything along the lines of Langzeit moly, or like said above, anything that mentions moly will work. It's all the same molybdenum graphite
molybdenum disulfide grease = owl ****
my favorite is molygraph but just about anything with moly in the title should do, it's a high pressure grease that you are lubing plastic with, exceeding the raiting of the grease is unlikely
Awesome guys thanks - we have this **** at the garage called.... Langezeit or Langzeit and it has the word Moly on it - its grey I believe... should work?Originally Posted by winfred
