Results 1 to 10 of 15
Thread: Replacing nylon shifter cup
    PA
    Default Replacing nylon shifter cup
    I know I know I should spend the $300 on a UUC short shift kit and I probably will, just not now. I rebuilt most/all of my shift linkage since my motor was out - got UUC delrin bushings for the carrier, new clip for the carrier, new yellow washers everywhere, new T-Junction piece on the selector input and lastly I ordered the nylon cup for the shifter ball but I have yet to replace that. The driveshaft is still out so I have access... is there any instruction on how to replace that thang?
    Thanks all
    Dec 2005
    Brisbane Australia
    Thanks all
    have you got it and the gearstick out of the shifter arm yet? you can do the "turn clockwise 90 degrees thing". But i found it easier to kind of push in the tabs with a screw driver that hold it in the groove on the side of the shift carrier, one side at a time whilst kind of pulling up on the stick so it'll stay in.
    ie push left side in pull up LH side tab stays depressed do the same on RHS and pull it should come out. I don't know how else to explain it. this was for a 318is but it should work
    There was a recent thread about swapping the M motor into a touring, one of the frequent posters here. He had a write up that included a bunch of different shift levers and part #s, one of those ought to accomplish what you want to do for a fraction of the "kit" price.
    A vintage Hurst T handle would be cool too. Turn it down and thread it for 3/8-16
    Dec 2005
    Brisbane Australia
    woops just realised i didn't answer your question of putting it in. once its on the ball you just put it with the tabs line up with the grooves on the side of the carrier. then i just tapped on the top of a tabs with a screw driver until they went in. easy.
    El Paso TX
    bentley actually has the best directions on taking it out. made NO sense until I had the thing sitting on my kitchen table, and then read the directions.
    I think I used a pair of thin blade flat screwdrivers and a box end wrench as a "hammer" to get it to rotate, and a pick tool to lift up tabs that got jammed.
    Dec 2005
    Brisbane Australia
    Quote Originally Posted by attack eagle
    nice yeah i tried the rotation but i didn't have much joy, the wrench hammer idea would work very well to get it to rotate but i didn't think of it at the time.
    PA
    Is there a link to the online bentley, mine is at the shop w/ my car
    baton rouge, loserana
    theres a slot on either side of the rail, stick a screwdriver in there and wack it, that will kill the ear that's holding that side of the cup repeat for the other side, when you drop in the new cup make sure the ears pop into those slots, it usually takes a tap to seat them. the bosses kids 98 m3 came with some super duper uuc shifter and imho it's a piece of ****, it's a machined insert that replaces the nice tight fitting cup that basically converts the shifter to a 2002/320i style upper/lower cup and spring set up that sucks ass, the car was undrivable when we got it and all i could do to it barely made it tolerable
    stick with the stock set up and sellect your favorite factory shifter for throw reduction
    PA
    Winfred should I take the carrier down and out of the car? It sucks because I installed that pin/clasp on the trans that holds the carrier in without installing the UUC delrin bushing jobbers. So now I need to clasp it. That **** was HARD to clasp since I had bought a new clasp. Do I attack that from the front or back of the trans? Argh.
    I wish I had a pic of how to get @ this shifter cup thing
    This is likely what you're looking at, correct?
    Here is old thread on shifter rebuild, you may have seen this already
    Relevant excerpts from the thread:
    5) Remove plastic mount (#7) and shift lever with needle nose pliers by turning and pushing up from below
    Con't.................
  1. E38 Shifter Mod Q
    Last Post: 07-18-2007, 03:03 AM
  2. Z8, 1.9Z3 or e36 M3 Shifter - which one one to get ?
    Last Post: 03-08-2007, 03:30 PM
  3. nylon hydraulic seal for LAD - sources?
    Last Post: 04-13-2006, 09:19 PM
  4. e34 short shifter?
    By motuman in forum 5 Series BMW
    Last Post: 07-28-2005, 08:29 AM
