Results 1 to 3 of 3
Thread: Could somebody post a pic or 2 of the Inside of the M30 engine Oil Pan?
    Minnesota
    Default Could somebody post a pic or 2 of the Inside of the M30 engine Oil Pan?
    To make a long story short, I had a timing chain guide failure which cause the chain to jump the sprocket. Mayhem ensued including broken valves. Top end is all back together now with new valves and fresh valve job. Now I am now trying to fish out the plastic pieces of the chain guide from the bottom of the oil pan via the level sender hole and need to see where pieces may hang up.
    Jeff in MN
    87 535is 245k Recent top end re-work
    88 528e 290k
    90 535i 115k
    98 740i 115k New Magnaflow Cats, No More Codes
    Either drop the pan and get it all out or rely on the screen in the pump.
    A case could be made for rinsing the pan out as well as possible through the drain hole.
    Minnesota
    Default Been thinking along those lines too. Screen could catch
    most, but I am worried about a large chunk blocking flow into the screen. Going to try and borrow boroscope from work and get a better look. But I really am trying to avoid dropping that pan. Did it 2yrs ago, SUPER PITA.
    Jeff in MN
    88 528e 290k
    90 535i 115k
  1. Replies: 78
    Last Post: 02-23-2008, 05:50 PM
  2. Replies: 22
    Last Post: 08-12-2006, 11:52 AM
  3. 1994 530i I BROKE THE 4 INCH BOLT INSIDE OF THE ENGINE
    By Green Bimmer in forum 5 Series BMW
    Last Post: 08-11-2006, 11:52 AM
  4. Replies: 3
    Last Post: 08-08-2006, 11:02 PM
