Okay you have just indicated your starter is fine.
Not firing and not cranking are two totally diferrent things.
You need to make yourself clear.
If the motor cranks over but
does not fire until the second attempt then the starter is okay, in which case the ignition or fuel system may be at fault.
Not
cranking until the second attempt could be due the starter, a start relay, ignition switch or a bad connection. etc, etc.
So take a deep breath, think about it and try and explain it all again
CLEARLY so we can all understand!
