http://www.bmwe34.net/e34main/mainte...e/FuelPump.htm
Seems like i answered my question. Anyone know off hand what style pump came on the 89, i hear there where 2 different styles? Is there a relay at all?
Dave
Hi again,
Thanks for all your help in my last post. I ruled out the starter not being the issue and i was able to tow her to the firestation to work on her.
It seems now the fuel pump is not priming. In my mustang, i can hear the pump "prime" when i turn the key to on. I don't here this on the 525. She is still not starting. I actually got her to quickly fire up with some starting fluid, then she quickly died. She defiantly isn't getting fuel. Do you guys know if there is a relay for the fuel pump or anything else to check. Autozone carries the pump for $300...ouch! I checked the fuses, they are ok. Is there an easy way to get at the pump without dropping the tank?
Thanks again guys, I can't wait to get her back on the road!!!!
1989 525i Bonzibeige-ish
Dave
Great, thanks for searching a bit.
Folks are probably getting tired of seeing this pic, but here we go again.
Relays are located under a black plastic cover behind the passenger side strut mount. I'm bypassing the relay in the photo in order to test the pump.
A used pump may be a solution if $300 is too steep. I just picked one up from a board member for ~$50. They can be had on ebay or from Bavauto for the same.
Dave M
*RIP Oskar the DOG*
Dave I saw on the main page you were the last to post and the topic was "Fuel pump not priming" and I was like wtf that pumped worked 100%!!! (the one I mailed you). Haha
Oh, we'll see about that. I expect a 100k warrantyOriginally Posted by Jon K
*RIP Oskar the DOG*
