Originally Posted by
sneekens
sorry for the OT:
just saw your coilovers, what is the brand? is there for the e34's? what shocks are used?
thanks
The suspension on the 635csi race car consists off:
Full Ground Control setup. Advanced Design double adjustable shocks, Modified strut housing, Coil over front and rear, GC camber plates, GC rear shock mounts, 25mm/19mm adjustable sway bars, Adjustable front sway bar links, Sway bar mounts reinforced, adjustable trailing arm bushings, urethane race sub-frame bushings.
You can get the ground control sleves and springs and use Bilstein shocks also, you need to modify and weld the housing though. I bought the car with the suspension already done. Dave did his.
