Results 1 to 9 of 9
Thread: black headliner looks good
    Default black headliner looks good
    new black with the old grey sunvisors and trim, nice contrast.
    And of course nothing could go wrong as he mentions
    and followed the instructions per Shogun
    http://www.bimmerboard.com/forums/posts/487384
    It does look good! You know anything about that place's material, how close is it to factory? Also, I notice a few ripples behind the sunroof.
    What's the trick to removing the headliner? Do you really need to remove the front or back windshield?
    Regards,
    -Trevor Ely
    '88 535is
    '95 M Sport 540i (1 of 200)
    '91 M5
    Jan 2008
    Quebec, Canada
    Quote Originally Posted by MTechnik540i
    Regards,
    Nope, removing the headliner is a piece of cake.
    -Remove the Sun-Visors (8 screws for both)
    -Remove the Courtesy Lights all around
    -Remove the Sunroof Button
    -Remove the Handles (8 screws for the four)
    -Remove the Hange Hinges if you have (2 screws for both)
    -Put the Front Seats ALL THE WAY BACK
    -Slide the headliner out through the rear doors
    ^^Thats for the Sedan^^
    Touring is almost the same except it comes out in 4 pieces, not 1
    BMW E34 1992 525i Touring
    Quote Originally Posted by bad_manners_god
    Awesome, and no trouble with bowing/creasing the headliner panel?
    -Trevor Ely
    '88 535is
    '91 M5
    Jan 2008
    Quebec, Canada
    Well, if you go with OEM headliner it's easier but I did mine in a leather-look. Took time, patience and a heat gun.
    http://www.bimmernut.com/forum/showthread.php?t=36857
    I have a touring so it was easier with 4 pieces since I didn't have to worry about the glue drying, I also did the pillars to match.
    Right, but I was talking about when you're removing the headliner, you can remove it without bowing the headliner...Don't want to leave creases.
    -Trevor Ely
    '88 535is
    '91 M5
    Jan 2008
    Quebec, Canada
    Can't tell you the truth cause I have a touring, not a sedan, so it's 4 pieces, not 1....
    Here is a link from shoguns sig, pretty helpful:
    http://www.wlsheadliners.com/tutorials/bmw/
    GREAT!!!
    and I thought I was getting close to finishing my upgrades!
    But No!
    Now I have something else to add to the list. LMAO
    I like it!
    E30 318iS & BMW K1200LT
    it's all on my website,
    pics
    http://www.bimmerboard.com/forums/posts/143818/
    Source: Nov-1988 750iL, no sunroof, left hand drive, manual rear window blind
    Job: replace headliner
    Time: say 6 hours, 2 people plus an occasional third
    Guidelines:
    1. Drop door rubbers from the top and both sides of all doors. You can leave the lower scuff plates in place.
    Drive the fronts seats forward as far as possible and remove the headrests – they pull straight out – can be stiff.
    2. C pillar facings
    Pull rear seat sidelights from C pillar casing, rear edge pulls out first.
    Though the space you can see (with torch) the top bayonet clip. Put your hand in behind the clip and pull straight inwards. This releases the top of the casing. The problem is that there are two lower plastic clips on the casing that are brittle and fairly easy to break if you rush it. The bottom of the casing is strongly pushed by the back seat so carefully pull the edge of the seat away from the casing and with your other hand as low down on the casing as possible, pull the casing upwards at 20 degrees and forward. You should get both clips out intact.
    Unplug the side lamp. That's one done now do the other!
    2. B pillar Lower half casing
    Move the front seat forward as far as possible.
    With a small flat screwdriver pop out the two plastic plugs on the lower half casing. This frees the bottom of the casing. Swing the bottom out about 10 cm and pull downward. This releases the top of the casing.
    Upper half casing
    With the lower half casing off you can see the lower 2 bayonet clips on the upper half casing. Pull straight inwards. There is another bayonet clip at the top. Put your fingers behind the upper casing and pull down and inwards.
    Note: the upper metal clip can fall out of its socket in the roof when you remove the upper casing. Make sure to replace it or renew it; it’s all too easy to miss this when you’re putting the liner back in.
    3. Remove B pillar upper seat belt mounting nut (17 mm). This allows the casing to drop into the foot well.
    Note: If you want to recover this casing you’ll have to release either the belt from the seat or release the belt reel from the bottom of the B pillar. 17mm bolt. We took out the belt reel but now find that the reassembled seat belts are somewhat slow to retract. If you can clean the upper casing in the car you will save some time. We were thinking to replace the covers but they cleaned up really well. Chalk this up to experience.
    4. A pillar casing
    3 simple bayonet clips running down the center of the casing. With fingers front and back of the casing, pull in towards the center of the car. Start with the top clip, then middle, then bottom.
    5. Grab handle mounting screws
    Note: each handle is secured to the board by two small plastic plugs. Do not try to pull the handles off the board – just remove the mounting screws.
    Pull the handle down and remove the small caps with a small flat screwdriver. Take out the two nice large cross head screws. This is not as easy as you might think as the spring retractors tend to load the headliner board as the screws come out. Three hands are definitely useful to preserve the board. One person has to hold the base flat against the board while the other holds the handle down and wields the driver.
    6. Rear vision mirror
    Turn the mirror’s stem and base anti-clockwise about 45 degrees. This should release the mirror. Remember the feel of it coming off as you will have to reinstall it later.
    7. Remote control switch
    With your fingernails pull the remote down and unclip the wiring.
    8. Vanity mirror light assembly
    As per 7.
    9. Main ceiling light assembly
    As per 7. In our case it seemed that it was easiest to remove the left-hand end first. There is no easy electrical plug at here so leave the assembly hanging down.
    10. Recommendation. At this point – particularly if you’re working alone – pass two simple straps over the roof and under the headliner – one through each door opening. Once you start to release the front and rear board attachments these straps should stop the board from sagging and breaking. No need to be really tight.
    11. Sun visor base and end clip < 2 damn torx screws each>
    The guy who invented these is not my friend.
    Regardless, take out the screws and disconnect the wiring. One novelty of this car is that everything imaginable (and then some) is wired up. These electrical fittings are simple spade connectors and can be really tight – have a small pair of needle nose pliers handy!
    12. Rear window blind holders
    Unscrew and remove (for some reason there is no electrical connector)
    13. Da board
    Work your fingers between the board and the windscreen. In Shogun’s car the liner here was stuck to the windscreen sealant. Slowly pressure the liner material in 4cm sections and it should pull away from the windscreen.
    There are two clips on the rear edge of the board – they are about 5cm inboard from the blind holders. Put your fingers under the board and pull down.
    The board is now pulled backwards about 10cm which should release the clips in the center of the board.
    14. Removing the board
    We were quite surprised to find that the board was in excellent condition and had retained its flexibility -- no cracks in this beauty. This made it relatively easy to remove -- but two people definitely recommended.
    Raise the passenger’s seat up as far as possible and put the driver’s seat as far down as possible.
    Release the straps and lower the board.
    Get on your 3d glasses.
    Turn the board clockwise (looking down on the board) and raise the righthand edge. Move it as far forward as possible.
    Raise the driver’s seat all the way. 5 hands would help here.
    You now can drop the left side of the board down further.
    Slightly bow the board (particularly the back right corner to get it past the left C pillar) and drop the back left corner of the board into the rear foot well.
    The board can now be slid out through the rear left door – this is a 750iL after all.
    If you’ve been paying close attention you now know how to put it back in again.
    Once out of the car, remove the plastic pins holding the grab handles.
    15. Removing the old foam
    The old liner should simply fall away from the board. Treat the old foam with respect. On Shogun’s car the foam turned to difficult-to-remove sludge if it was pushed or smeared. The best attack was to use a vacuum cleaner with the small corner nozzle. In most places, simply lightly dragging the nozzle across the board was enough to remove 99% of the foam. Stiff scrubbing brushes worked well in the recessed areas. To prep the surface it seems that steel wool pads with concentrated detergent worked best. The final surface was really smooth and tack-free.
    16. Fixing the new liner
    Since Shogun had carefully sized the new stock, we chose the easy way -- glue first and trim later. The 3M glue Shogun got can be used as regular direct glue or contact glue. We decided to proceed in strips using it as direct glue.
    With the board flat and the inside facing up, we laid the new liner out and folded the rear half back. Starting from roughly the center, we painted the board with glue in 15cm inch strips from side to side – no glue was put on the edges or backside of the board.
    One problem is that the glue was yellow, same color as the board. It helps to have another set of eyes checking for dry areas. We used the glue direct from the can without any thinner. That necessitated a stiff brush to get good adhesion and a thin even film. We put down a 50% film, you could see the board thru the glue but only just. The glue sets quickly and the 15cm strips seem to be good compromise. Once the glue is down, spread out the liner to cover. Luckily the glue sets quite quickly so in the cavities of the grab handles it is relatively easy to push the liner in, hold for 1 minute and it should stick. We did not tension the liner when we laid it down and found that there were no wrinkles at the corners (my worry). Warning: the rear corners are sharply curved and you’ll need care in using enough glue to ensure that the material wraps smoothly and sticks well.
    The overwraps we left till later. We then did the front half.
    Take a break because you’ll have worked up a sweat by now.
    It’s essential that you have sharp craft knife and a pair of sharp scissors. Take it from me, the material we used was damn tough to cut, probably yours will be the same. One point is that all devices that pass through the board really require the material to be cut out of the opening – except the rear blind holders. I tried to cheat by leaving the material in place but the stress seemed too much. My recommendation is to find each corner of the opening with your finger, use the craft knife to make a diagonal cut to the center, and then use the scissors to trim the sides and ends. WARNING: there is precious little room for error and it is very easy to cut the opening bigger than needed –trust me. Keep the liner flat and the scissors vertical as you cut and do not pull the material as it can stretch a lot. It’s better to be conservative and cut twice.
    For the small holes we used a small pointed soldering iron which melted the liner.
    One of the sun visor cavities was short of glue but when we cut out the center light opening it was possible to carefully pull the liner away and use a long thing stick to add more glue. Worked a treat.
    We then turned the board over and laid it against some chairs.
    Starting with the rear end, we cut the corner reliefs so that the cuts ended 5mm inch from the edge of the board. The idea is that when the liner is wrapped over, the ends of the cuts are slightly past the edge of the board. Cut the corner piece so it ends about 15mm from the edge of the board – the width of corner was 5 mm at the bottom. Put down a dab of glue and fold the corner piece down – hold until the glue sets. Shogun’s material is as tough as boot leather and there was no worry about the center piece breaking. We cut the rear liner to a width of 10 cm and folded it over after cutting out reliefs for the rear blind holders and the two rear clips.
    We then cut the material along the sides to a width of 15 mm and glued it down.
    The front edge work followed the rear.
    Refit the grab handles and hold with the plastic pins. This design is marginal as the pins fall out if treated roughly.
    17. Refitting the board
    The reverse of removal.
    Use the straps to hold the board up as working overhead is tiring and errors can happen.
    The trick here is to engage the center clips and then the rear clips. This means that the board starts towards the back by about 20 cm, the center clip holes are picked up, the slides forward past its final position by about 1cm, the back edge is held up and the board is slid backwards to engage the rear clips. Phew. 45 minutes of excitement in a few words.
    Warning: the center clips are not too strong and can be broken off if the board is pushed forward too strongly. Fitting is easier if you turn the car over on its roof – use a nice blanket to prevent paint damage.
    Feed the center interior light assembly through the hole so its hanging down again. Feed those wires for the sun visors, vanity lights, and remote control through the holes.
    Refit the grab handle mounting screws. 3 hands needed here as if a plastic pin pops out its real difficult to refit it.
    Refit the rear blind holders, and all the stuff at the front.
    Note: the hardest part seemed to be the sun visors and their end clips. It was very difficult to get the screws lined up and started. I’d recommend you buy a driver with a comfortable handle – it will give a lot more control over the screws. Using an awl to line things up first is really necessary.
    Refit the pillar casings and the door rubbers.
    You did remember to check that the bayonet clips were still in place above the B pillars before refitting the board, right?
    Congratulate yourself.
    Here we did it on a E32 750iL Highline
    http://infinitier.ddo.jp/e32/page/ma...inte_50812.htm
    http://8810.teacup.com/750hiline/img/bbs/0000527M.jpg
    Here on E31 850
    http://8810.teacup.com/750hiline/img/bbs/0000509M.jpg
    http://8810.teacup.com/750hiline/img/bbs/0000508M.jpg
    http://8810.teacup.com/750hiline/img/bbs/0000507.jpg
    http://8810.teacup.com/750hiline/img/bbs/0000506M.jpg
    http://8810.teacup.com/750hiline/img/bbs/0000505M.jpg
    And more than 10 other BMW's.
    I buy the material directly from Germany on large rolls of 30-50 meters length.
    Distributed to all club members here in Japan and the rest goes into the auction house here.
  1. 1990 525i black/black 140k miles 4 SALE
    By ber55ber55 in forum 5 Series BMW
    Last Post: 03-15-2008, 01:40 PM
  2. For Sale: 1995 BMW 740iL black on black Houston, TX
    By turbo mike in forum 7 Series BMW
    Last Post: 10-23-2006, 10:02 PM
  3. good OZ black interior
    Last Post: 09-15-2006, 07:39 AM
  4. Good place to find OEM style/color headliner material?
    By atomicDog in forum 5 Series BMW
    Last Post: 08-23-2004, 07:03 PM
