Quote Originally Posted by mitsi_matt
hi first post so let me just introduice myself first: my name is matt and i have just bought a 92 e34 touring in near mint condition having just sold my s13 200sx with 360ish bhp i thought it a necessary 1st modification to fit a wizard of nos nitrous kit running 150bhp jets, then 18" rondell alloys and now for my first question: have bought a jamex suspension kit shocks & springs(not suitable for cars with self leveling suspension) thinking mine was not equipped with this, to discover when i pulled a wheel off have got it, if i delete the self leveling will this kit fit? if not can i fit the front & just springs on back and lower the self leveling as described in threads ive found when doing a serch on this forum or do i have to leave standard back springs in place? sorry for such a large request for first thread but this is now my new home so hope will be as helpfull as sxoc was when i had the 200. please bare in mind when ansering that car is for drifting so the harder the back the better, i know it's a strange choice but i wanted to be different.
Hi there, I also have a 92 Touring. I also had the rear self leveling system deleted because of a faulty pump so i took out th whole system and replacd them with regular shocks and springs and no problem. Only problem you will get is that a "SUSPN LVLING" message on your cluster computer and will limit your speed after 110mph because the computer things that the rear suspension is too low and will restrict the cars output after 110mph(180km)
To bypass this, all you have to do is remove your rear seats and find the 21 pin connector next to the battery and connect pins 12 and 13 together with a wire to trick the computer into thinking the rear suspension is fine. To idtentify the pins:
the 3 wires in the center row of pins on one end are the sensor wires, pins 12, 13, and 14. Pin 12 (three from the end of the middle row) is a black wire with brown stripe and yellow dashes -- this is the sensor output. The next pin (13) is the ground, and the end wire in the middle row (14) is +12V power.
And here is a thread you should save:
http://www.bimmernut.com/forum/showt...ighlight=Suspn
