Results 1 to 2 of 2
Thread: Problem on 96 750iL Help pls!!
    Feb 2008
    Nr Cambs
    Default Problem on 96 750iL Help pls!!
    Hello, a good friend of mine has a 1996 750iL and it has developed a problem. when runing at 50 or so mph and he accelerates its stutters a bit or hesitates. does not pull cleanly. He always uses good fuel and the car is in vgc. is this a known issue or has anyone had the same thing? Thanks for any suggestions.
    Use the search on this board, there are E38 drivers only
    http://www.bimmerboard.com/forums/e38/
    Could be many things, for example bad speed sensor, fuel pump defective, fuel filter dirty, fuel regulators defective, CPS giving no clear signal etc.
    That neesds a diagnosis at the dealer with the DIS, that is fastest to ceck.
    Otherwise, go to my website below, and see under rough idle / now power.
  1. OT: Opinions on E38 750il
    By Jimbo in forum 5 Series BMW
    Last Post: 07-17-2007, 08:35 PM
  2. lost a bid for E32 750iL by 10 $
    Last Post: 09-24-2006, 12:46 AM
  3. '88 750il Reverse Problem
    By jmhuot in forum 7 Series BMW
    Last Post: 10-22-2005, 12:09 AM
  4. 750il 3.15 LSD available
    By Craig in Davis in forum 5 Series BMW
    Last Post: 09-13-2005, 08:17 PM
  5. E32 750iL used car review
    Last Post: 08-05-2005, 07:34 AM
