M60 Rough Idle
Ferret,
This is a well known problem and been well covered by this board's gurus.
All it takes is one buggered up gasket, rubber hose or cracked clamp point to mess up your idle and make you
Check out this thread in the archives:
http://www.bimmernut.com/forum/showthread.php?t=19452
Pics of intake manifold removal:
http://rides.webshots.com/album/5475...sR?vhost=rides
Before you start removing cats and exhaust manifolds, I would make sure that the intake system doesn't have a leak; and there are many places it can. I replaced all rubber that had anything to do with the intake manifold, the Front and Rear intake gaskets, the PCV plate itself, and the O-rings.
Also, while I had the intake manifold off the car, I had the injectors refurbed and calibrated. They looked like crap. (See the pics) They're right there in hand, so you may as well check them out.
I'll look around for that parts list if I still have it. (The bolts BMW uses on the front and rear intake plates are crap. Replace them with real ones.)
Happy Ferreting!
Ramon
1994 540iA Nikasil EAT Chip
Tampa Bay, Florida USA
