Just read this on a forum in the U.K., might be interesting for some in the U.K.:
Fuchs Lubricants of Germany have recently made available a range of BMW Approved gear oils only previously seen in Germany.
www.opieoils.co.uk is the only current UK supplier of these having imported them specially from Fuchs Lubricants Germany.
The oils are as follows
Fuchs Titan Sintofluid SAE 75w-80
Fuchs Titan Sintopoid FE SAE 75w-85
Fuchs Titan Sintopoid SAE 75w-90
Fuchs Titan ATF 3353 (ATF)
We asked Fuchs for a list of applications for these oils and have recieved the following advice:
Manual Gearbox Green Label - Special Oil
Titan ATF 3353
http://www.opieoils.co.uk/p-969-fuch...ion-fluid.aspx
Manual Gearbox Yellow Label - MTF LT1
http://www.opieoils.co.uk/p-981-fuch...ion-fluid.aspx
Manual Gearbox Yellow Label - MTF LT2
Automatic Transmission Black Plate - Dexron III
Titan ATF 3353
Automatic Transmission Green Plate - Multi ATF
Titan ATF 3353
Rear Axle:
For fuel economy (non lsd)
http://www.opieoils.co.uk/p-982-fuch...-gear-oil.aspx
For Higher Mileage vehicles (non lsd)
http://www.opieoils.co.uk/p-983-fuch...-gear-oil.aspx
We believe that some of these products are in fact the BMW factory fill oils as Fuchs has many BMW factory fill positions.
Your Club Discounts are available on these products when you are registered as a Club Member at www.opieoils.co.uk
Cheers
Guy & The Opieoils.co.uk Team.
oilmans website:www.opieoils.co.uk
e-mail:sales@opieoils.co.uk
tel:01209 215164
