Results 1 to 5 of 5
Thread: E34 520i ~ 18mpg ! Hose help and more :)
    Feb 2008
    Hertfordshire
    Default E34 520i ~ 18mpg ! Hose help and more :)
    Hi , New to the board and hoping someone can help..
    I recently bought a 92 E34 5201 after my Toyota Celica vvti basically blew up..
    I was lucky enough to get hold of this old beemer girl but she has been neglected for at least a year if not longer ( had been standing for over a year ) She only has a genuine 106,000 miles but due to neglect although a cheap buy I am having to replace bit n bobs and chase problems....
    I have one big problem that is leading me to chase another..
    basically faults are as follows:
    1. Only achieving 18mpg !!! yes 18 mpg
    2. Rough idle ( car rocks ) when its in Park or neutral when hot...rough idle is a drop in revs now and then then a pick up..Hunting
    3. Smells like she is running rich but have to floor throttle to get her started from cold.
    i have already replaced sparks, oil and oil filter, air filter..
    I know some issues could be idle control valve, and im planning to give this a good clean with carb cleaner shortly..
    The main issue I have in slowly problem solving at the moment is that im sure a lot of the mpg and rough idle issue is connected to vacuum hoses..
    I know 100% for sure i have a cracked hose with no clip or clamp ....the one that comes of the main inlet pipe between MAF and throttle body and goes to the ICV.
    I also have a bizzare almoost laughable pipe i need to sort..
    On the crank case at the front ( Rad front and same side as oil filter) I have what can only be described as a piece of yellow garden pipe ( yes garden hose pipe !) lose and unclamped on this location . It then dissapears under the inlet manifold????
    i have an old version of a BMW Tis , a pdf version of Bentleys acces to OEM parts and always search by my Vin njumber for accuracy...whats worrying is on the shematics it looks like the correct hose T's shortly after coming out of the crank housing cover?? to where I dont know...same on TIS ..it shows me it splits to a T and should even be a bracket there...all schematics never show where the hoses go....
    any advice about vacuuum hoses or where i can find a schematic of original to and from engine bay locations would be SUPERB..
    or does anyone have a similar E34 that they could have a peek and report back to me...
    Will try to take a pic in a few days to help....you will wet yourself!!
    PLEASE HELP
  1. What is the P# for the hose that
    By BennyM in forum 5 Series BMW
    Last Post: 08-26-2009, 09:08 PM
  2. My E34 520i
    By e34520gt in forum 5 Series BMW
    Last Post: 02-05-2007, 06:35 PM
  3. My 520i
    By robin in forum 5 Series BMW
    Last Post: 05-30-2006, 02:48 AM
  4. e34 m50: is my hose ok?
    By shragon in forum 5 Series BMW
    Last Post: 10-27-2005, 01:42 AM
  5. NEED HELP WITH 520i E34 M20
    Last Post: 06-04-2004, 05:05 AM
