We have disassembled a complete steering gear with Servotronik function and replaced all O-rings and seals etc.
When disassembling the foreseeable happened that the steel balls fell off inside.
As the temperatures are presently cold we used grease and put the steel balls back into the system and then put on the counter part. But that is not the official way I assume.
Here is the pic of the part in question, on the right hand you see a plastic cover. After removing this one one probably can insert all the balls into the system there.
But as we were not aware how to open that plastic, we used grease and reentered the balls from the front.
Question: how to remove/open the plastic piece?
Is that screw type? Or just pull straight out? With clips?
Actually that was a steering gear from my parts E32 750 from 10/88, the steering gear is from ZF.
Numbers written on it: 252910/0918 ZF 8054991107 11340930
The gasket set for the overhaul has the p/n 32 13 1 134 768
The gear has the following part numbers
RMFD HYDRO STEERING GEAR SERVOTRONIC till 09/1989 32131134105
RMFD HYDRO STEERING GEAR SERVOTRONIC 09/1989 -04/1990 32131136827
HYDRO STEERING BOX SERVOTRONIC from 04/1990 32131138274
RMFD HYDRO STEERING GEAR SERVOTRONIC from 04/1990 32131138566
SERVOTRONIC till 04/1990 32431162703
http://www.bilder-speicher.de/080129...ting-page.html
More pics here on the German board
http://www.7-forum.com/forum/24/uebe...ebe-87034.html
