Results 1 to 7 of 7
Thread: Heater temp
    Nov 2006
    Maryland
    Default Heater temp
    My car doesn't produce heat until I really accelerate the engine, like when i start driving on the highway. Also, when I drive on the city, the heat cools down until i rev the engine again. What's causing the temp loss in the climate control? Also, the blower settings 1-3 are intermittent, sometimes they work, sometimes it doesn't, or it works then it goes out and sometimes it doesn't work then it kicks on while driving. bad resistor/sword? or need to clean the controls on the other side?
    You have at least 2 different problems there.
    1. the blower fan speed
    that is controlled by the sword or by the resistor, depending on production year. See Bruno's website for details.
    2. The temperature problem
    That seems to be a stuck/broken thermostat in open position.
    May 2006
    Antwerp, Belgium
    For problem 1) heating: if the temp needle for engine coolant temp stays nicely in the middle: look at your aux waterpump instead.
    For problem 2) fan: before buying a new 'sword' or resistor: check Ferret's thread about the blower control knob fix. Many have found the actual knob to be the culprit.
    2008 audi A3 1.9tdi
    (former 1991 520i LPG)
    Nov 2006
    Maryland
    Engine temp is fine, and i also replaced the coolant, thermostat, coolant temp sensors and water pump. Not too long ago. Where do I check my aux. water pump?
    About the blower, i think that is it failed I wouldn't have 1-3 working ever. They do work from time to time so i think something needs to be cleaned or adjusted. I just don't know how to do it. Haha
    May 2006
    Antwerp, Belgium
    aux pump is under double heater valves in engine compartment near firewall
    look here
    As for the fix with the knobs in the center console: look up Ferret's thread on the subject. It's a very nice how-to guide.
    2008 audi A3 1.9tdi
    Nov 2006
    Maryland
    Are the workings of the climate controls all the same for every production year?
    May 2006
    Antwerp, Belgium
    Quote Originally Posted by ///Sniper535
    Large parts are the same AFAIK.
    2008 audi A3 1.9tdi
  1. heater temp light
    By 525ikicker in forum 5 Series BMW
    Last Post: 01-28-2007, 07:59 PM
  2. Oil Temp/Press & Water Temp Gauge Install
    Last Post: 06-26-2006, 01:25 PM
  3. Replies: 4
    Last Post: 06-01-2006, 04:23 AM
  4. Replies: 16
    Last Post: 12-02-2005, 08:20 AM
  5. Replies: 4
    Last Post: 01-14-2005, 10:19 AM
