The follwing are descriptions of new pumps from e-bay and BMA. realoem spits out the part # 16141181354 which matches the second description. However, the BMA website lists a pump which better matches the first description. Hmmmmm........
I know I could/should pull the pump to kow for certain, but does anyone know with confidence what pump I would need?
THIS AUCTION IS FOR A NEW OEM BMW FUEL PUMP PART NUMBER 16 14 1 180 318 WITH BOSCH NUMBER 0 580 453 021.
THIS PUMP HAS A LARGE BRACKET AND A SIMPLE FITTING FOR THE OUTPUT HOSE AND PLASTIC HOUSING .THIS PUMP WILL FIT :
M5 1991 - 1993 E34
525I 1989 - 1995 E34
525IT 1992 - 1995 E34
535I 1989 - 1993 E34
735I 1987 - 1992 E32
735IL 1987 - 1992 E32
THIS AUCTION IS FOR A NEW OEM BMW FUEL PUMP PART NUMBER 16 14 1 181 354 WITH BOSCH NUMBER 0 580 464 995 .
THIS PUMP HAS A SMALL MOMUNTING BRACKET AND A BANJO FITTING . NOTE THAT THIS PUMP DOES HAVE A EXTERNAL PRESSURE REGULATOR. YOU MUST DETERMINE WHICH PUMP IS INSTALLED IN YOUR CAR. THIS PUMP WILL FIT :
M5 1991 - 1993 E34
From BMA website for a 91 525:
E34;Internal Check Valve w/ Large Dia. Shock Absorbing Ring;61 321;Packing Size:PIECE; Years:; Per Car Qty:1;
