Results 1 to 4 of 4
Thread: temp gauge showing cold
    Texas
    Default temp gauge showing cold
    The water temp gauge on my 1991 525i/A (215,354 miles) is showing colder than normal. It normally indicates a dead center reading. It is now on the hash mark just left of center. About 9000 miles ago I replaced the thermostat/water pump/fan/fan clutch/belts/fan shroud. It just started doing this yesterday. I drive 28 miles (40 minute drive) one way to work and it is usually in the 80's outside during my morning drive. The temp should be well above that. Is it a faulty gauge or sensor? Thanks in advance for the advice.
    Colorado
    Brian,
    Cheap check....remove and clean contacts on your sender,I was lucky enuff to cure the problem I had.
    HTH,Mike
    mikey535im...........1991 535im , Schwarz , H&R/Boge gas ,17" Style 10's , EAT Chipped :eek: Colorful Colorado
    Texas
    Quote Originally Posted by mikey535im
    Brian,
    HTH,Mike
    Thank you Mike....I'll give it a try this evening.
    Unregistered Guest
    Default Might be stuck open as mine was a few weeks ago.
    Quote Originally Posted by brian_s
  1. help!!temp. gauge
    By bmwrp8 in forum 5 Series BMW
    Last Post: 08-06-2008, 03:36 PM
  2. Oil Temp/Press & Water Temp Gauge Install
    Last Post: 06-26-2006, 01:25 PM
  3. Replies: 6
    Last Post: 12-11-2005, 12:51 PM
  4. temp gauge showing cold
    By brian_s in forum 5 Series BMW
    Last Post: 05-20-2004, 12:52 PM
  5. temp gauge showing cold
    Last Post: 05-20-2004, 09:03 AM
