I Guess you may all throw your hands up in horror and say "must change both!", but I just want to change one (damaged) side as a temporary measure.
What I need to know is are the right and left units the same/interchangeable?
My local breakers has a car which appears to have had the right hand side changed as the shock absorber looks in good condition compared with it's left side.
As you would expect its the left side that needs changing on my car! The only thing I can think which may prevent the right hand side one fitting is the position of the 3 bolts at the top of the spring mounting.
