Results 1 to 3 of 3
Thread: E32 750i master cylinder in an e34 535i
    Default E32 750i master cylinder in an e34 535i
    I've been told on here it will not work previously, I couldn't find the post, however i was chatting to another gentleman who said he had done the modification and it worked. he said he had to move the abs unit a little and remade 2 brake lines.
    So whats the deal guys?
    Kris, the brake booster unit of the 750 is hydraulic and runs with Pentosin, same like the very old E32 730 and 735. Later they used vacuum. Hydraulic brake booster units are on all E32 750 and E31 850.
    A guy next door from you, Max Fretter had modified his old 730 from hydraulic H31 to vacuum,
    you can see that on my website far down under Max's website, maybe that helps.
    But actually you were talking about the master cylinder, of course these things work together, so Max's info might help.
  1. Master Cylinder Help
    Last Post: 07-04-2006, 10:20 PM
  2. master cylinder gone bad?
    By panzershreck in forum 5 Series BMW
    Last Post: 08-19-2005, 09:44 PM
  3. Replies: 2
    Last Post: 02-24-2005, 05:24 PM
  4. 535 master cylinder
    By caster in forum 5 Series BMW
    Last Post: 10-08-2004, 07:45 AM
  5. Replies: 1
    Last Post: 08-31-2004, 10:54 AM
