Results 1 to 2 of 2
Thread: Need 1993 740i oil change details (my first :))
    Mar 2004
    Default Need 1993 740i oil change details (my first :))
    Hey guys. I'm doing my first oil change this morning on my 93 740. Does anyone have a link to oil change directions for a 1993 740i? (The engine has been replaced so I think its the M62?) Correct me if I'm wrong. Anyway, The stuff I need to know is where to find the drain bolt, where to find the oil filter, what type of oil is recommended (brand included if it makes a difference), and how much oil to put in. Feel free to add in anything else you think I might need Thanks in advance.
    NJ
    Quote Originally Posted by micjordan
    The drain plug on my 4l is on the bottom of the pan. It can be removed with either a 17mm socket or an allen wrench (6mm?). The filter is in a housing on the left front of the engine, and requires a 36mm socket to remove the cap from the filter housing. Your new filter should come with a new rubber seal for the filter housing cap, and a new crush washer for the drain plug. Have 8 qts of oil available, and plan on using at least 7.
    Drew Zacharda
    6-speed Touring
    Drew Z
    Formerly 540iT/6, now . . . 3, 5, 7
  1. 740i won't start
    By Ethan in forum 7 Series BMW
    Last Post: 06-05-2008, 09:14 PM
  2. 1995 740i - 4.4L or 4.0?
    By rcbrown23 in forum 7 Series BMW
    Last Post: 09-21-2007, 11:47 PM
  3. My 740i go crunch.
    By Bimmer Nut Ed in forum 5 Series BMW
    Last Post: 05-10-2007, 11:38 AM
  4. Is this a good buy? 95 740i.
    By thedivision in forum 7 Series BMW
    Last Post: 07-14-2006, 11:22 AM
  5. Considering 1999 740i
    By Al Gray in forum 5 Series BMW
    Last Post: 09-26-2005, 01:34 AM
