Hey everyone... Has anyone had an outside air temp sensor go silly on them? Mine routinely shows 10 to 12 degrees below freezing when it's 60 and 65 degrees F out- especially when I run the air. Is it easy to replace? How much do they run? Thanks, and have a great new year!
Chris
The connections may be corroded. It's in the lower bumper just inboard of the left fog light.
Be warned that after disconnecting it you may get the -35 or whatever the low limit is. Disconnecting the battery put mine back to normal after being fixed.
