Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: "Cracked" con rods
    Default "Cracked" con rods
    Who can explain how these rods are manufactured?
    Winfred, aren't the M70 rods that way too? I've not been in the bowels of one but seem to remembr something written about it in the old sales literature.
    My understanding is that the process offers perfect alignment of the rod halves. What I don't get is how this can be done without distorting the part.
    PA
    Well most rods I know of are forged (yes most stock rods are forged) and they're made from two forgings.
    PA
    "The invention concerns an improved manufacturing method of a powder metal connecting rod with a stress riser crease formed in a side face by forging a sintered preform with a generally V-shaped notch in the side face. A one-piece forged rod is produced having a crease therein which is readily separated by a cracking process into a two-piece rod with a separable bearing cap. "
    http://www.patentstorm.us/patents/56...scription.html
    PA
    I think I did read that this might be how my rods were made - I am not sure
    Very informative. Unless I missed it the article doesn't address final machining but it must be done after the cracking as the force would certainly elongate the hole.
    Yours look like sintered, what do the mating surfaces look like? Machined or broken?
    PA
    I haven't taken them apart (per engine builder recommendation). I will let you know - I think they would crack them and then machine them, because even on cracked rods you never see the V groove
    baton rouge, loserana
    they are broken, that way it has maximum contact area and locks together, i have not been into the bottom of a v12 yet but the m60 i built a few months ago was powdered/cracked rods, i do know when a m60/62 sucks water #6,7 or 8 usually punches through the valley and out again the side before it stops
    Feb 2007
    New Forest, ,UK,
    After forging but before machining, they are split in a pre-machined groove by a bloody great hydraulic ram in order to achieve a molecularly perfect fit, Thats my understanding! By co-incidence BMW/Okrasa were the first to do it with the `80`s F1 engine I think,the rods are H beam but 90` from road engines.
    PA
    That is my understanding as well Barney
    Default Ross the m70 didn't have them but the
    newer m3,m5,z8's have them. Its cracked when the forging is still rough and then the sides and bore are machined.. Here's a pretty good description in this article
  1. Brake Pedal "Tapping"/"Knocking" Sound - 89 535i
    Last Post: 10-16-2007, 07:12 AM
  2. 530 "bucks" or "chugs" but driveshaft feels good....
    By 300k 5er in forum 5 Series BMW
    Last Post: 10-09-2006, 02:09 PM
  3. "Trans Program"/"Limp Mode" Redline a Engine?
    By JMI in forum 5 Series BMW
    Last Post: 06-12-2006, 10:51 PM
  4. Replies: 5
    Last Post: 01-09-2006, 01:48 PM
