Results 1 to 7 of 7
Thread: Power steering leak at banjo
    Sep 2005
    Goulburn Australia
    Default Power steering leak at banjo
    Hi all,
    I did a long search on this problem but couldn't find anything to answer my question.
    I had a leak from the PS reservoir (low-pressure hose weep). I replaced the hose and it worked fine. Issue is that I loosened the banjo bolt at the pump to drain fluid. On replacing the bolt with new genuine washers the fluid weeps around the washers. I've torqued it up correctly, done everything right (I think) but she still weeps (more like crying a river!!!). Any help with this problem would be great.
    Cheers
    Wingman
    '89 525i/A Exec 193000kms
    '94 Subaru Liberty AWD Wagon
    Looking for Merc 300TE
    NSW, Australia
    Mar 2004
    NJ
    There might be some crud between the washer and the bolt or hole. If so, it's probably screwed up the washers enough to warrant replacing them again....sorry. You can try to snug them a tiny bit more to see what happens.
    Sep 2005
    Goulburn Australia
    Quote Originally Posted by bmwpower
    I actually changed the bolt as well on the 2nd but still weeping on the bolt side as well. I'll do an extra thorough clean on the 'next' attempt. Thanks for the advice.
    Cheers
    Wingman
    NSW, Australia
    I found some banjo bolts which has cracks inside the winding. Pre-owner tightened them too much. fluid was leaking there.Pics
    http://www.bimmerboard.com/forums/posts/124919/
    Sep 2005
    Goulburn Australia
    Thanks Shogun,
    I know from experience how easy this can happen. I got a brand new one in now.
    Cheers
    Wingman
    NSW, Australia
    Default I've actually used a sealer on those joints...
    I've done the same repairs and had similar problems. It is true that the surfaces all need to be flat with no nicks or scratches, and no crud in there when tightening. But I've also coated the washers with a slight film of some type of gasket shellac to help seal it all. Worked for me.
    Robert K
    1991 535i
    Sep 2005
    Goulburn Australia
    Thanks Robert. I was talking to a mate last night who is a hydraulic mechanic by trade. He couldn't over stress the importance of clean surfaces. I find it funny that the 'genuine' washers provided by the dealer are steel and not copper?!?! Strange indeed.
    Cheers
    Wingman
    NSW, Australia
  1. power steering hose leak
    By Renman in forum 5 Series BMW
    Last Post: 12-23-2008, 05:17 PM
  2. Power Steering Leak
    By AllGo'n'Show in forum 7 Series BMW
    Last Post: 03-06-2007, 04:11 PM
  3. Power Steering Pump Leak
    By 95///M3 in forum 5 Series BMW
    Last Post: 12-18-2006, 03:05 PM
  4. 1999 528i, Power steering leak
    By gregp1962 in forum 5 Series BMW
    Last Post: 07-27-2006, 03:13 AM
  5. Help - Power steering fluid leak
    By Scott E in forum 5 Series BMW
    Last Post: 07-10-2004, 11:58 PM
