European Transmission has established a forum where you can ask special questions about tranny probs. Of course you can order also tech manuals, overhaul kits, reman trannies etc.
http://www.europeantransmissions.com/
Will my 4hp automatic transmission from my 1990 535 swap into a 1988 735? Would like to know if this just bolts on? Thanks
Most probably not, as the 1988 is probably the older version with 8 pins on the tranny.
But you can mix it possibily like Johan has done it
http://bmwe32.masscom.net/johan/gear...rbox_swap.html
Also read this
http://www.bimmerboard.com/forums/posts/480891
and compare the part number of both cars tranny
http://www.realoem.com/bmw/select.do...938848d4d39ea1
What is mentioned in the parts catalog is one thing, but in those old days they had a lot of stock, so they used up stock first and then changed to newer parts. So better check and count the pin numbers of both cars on the tranny.
http://s71.photobucket.com/albums/i1...pinplugtq3.jpg
