Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: sticking outer door handle?- solution
    Default sticking outer door handle?- solution
    Aug 2005
    West Portland, OR
    FYI - don't get the malaysian door handle seals unless you have a 91+ car, because they don't fit on the older ones, like my 89.
    EuroLux:. Private Detail
    Seattle, Wa
    Quote Originally Posted by CharlesAFerg
    Any idea where to get new ones for an older ('89) 535i?
    TIA
    what's the problem, Charles? What is the exact difference?
    01 DOOR HANDLE OUTER LEFT 1 up to 09/1991 51221928207 $59.15
    01 DOOR HANDLE OUTER RIGHT 1 up to 09/1991 51221928208 $59.15
    http://www.realoem.com/bmw/showparts...=41&fg=45&hl=1
    01 DOOR HANDLE OUTER LEFT 1 from 09/1991 51228138951 $59.15
    01 DOOR HANDLE OUTER RIGHT 1 from 09/1991 51228138952 $59.15
    I have better outer door handle gaskets than the ones from Malaysia. The ones from Malaysia/Thanks are very hard. I have sold >100 sets in Japan, but never got a complain.
    Wellington,New Zealand
    not necesarily..my door handle stick up,because it interferes with the trim around the handle itself..its an ongoing project.At the moment the trim is off..it doesnt notice on my car because its black!
    Gone but not forgotten
    Australia
    I've installed the new seals for my 89 and 90 cars without any problem. If you take your time to install them correctly then they work perfectly.
    That is what I thought so far. I tell all people which buy them from Maylaysia/Thailand to heat them up with a bit with warm/hot water or a hair dryer, that they become flexible. Especially now in winter time the gaskets are of course hard when cold.
    And I give them this instruction in Japanese with pics http://infinitier.ddo.jp/e32/page/ma...inte_50702.htm
    Nov 2006
    Mid-Atlantic, USA
    Probably as good a time as any to remind folks that WD40 is not a lubricant. Even if WD40 does help remove the corrosion and free-up the handle hinge, the best thing to do is to lubricate the mechanism afterward with a real lubricant that stays around to continue the job.
    Dec 2006
    I use silicone lubricants on my door handles.
    Aug 2005
    West Portland, OR
    I tried in both summer and winter, heated them up and left them cold, even left them in the sun. I did that, they don't fit properly, even when heated up - they would be too large, I'll show you guys.
    The little holes for the pins were like a millimeter too far apart to get the tiny little pins into. Every hole, because of the difference, would be about an extra milliliter too far away. The plastic piece was slightly too wide.
    The one from the dealer fit PERFECTLY. That proves I was doing it correctly. I still have a dealer piece that I haven't installed yet, I'll find my malaysian ones and show you. Maybe I got a bad batch, because I do remember some other people having the same problem.
  1. outer door handle gaskets E34, E32, E36, Z3 - NEW
    By shogun in forum Swap Meet - Classified Ads
    Last Post: 12-30-2022, 03:57 AM
  2. Help: Outer door handle broken
    By bimmerred535i in forum 5 Series BMW
    Last Post: 07-10-2009, 08:43 PM
  3. outer door handle gaskets in U.K. for sale
    Last Post: 02-10-2006, 03:52 PM
  4. outer door handle gaskets in the U.K./Ebay
    Last Post: 02-09-2006, 10:16 PM
  5. Drivers door handle sticking up when opening.
    Last Post: 07-27-2004, 08:55 PM
