Results 1 to 2 of 2
Thread: Is my Vibration Damper shot?
    Sep 2004
    Comox Valley, Vancouver Island, British Columbia
    Default Is my Vibration Damper shot?
    M60 engine....
    I have very pronounced engine shake/vibration at several spots in my RPM range. This is apparent in PARK and when driving....It becomes more pronounced when driving, especially in the higher gears at lower speeds where the engine is working harder.
    My local mechanics (small town) have disconnected the drive belt, checked the fuel and ignition systems all to no avail and the motor mounts have been replaced.
    They think it is the Vibration Damper....Has anyone have experienced this and if it is the damper where can I get one for less than $700.
    Is there a way to test the damper???
    Cheers,
    Kurt
    East Brunswick, New Jersey
    I am showing you the engine on the stand but removing the damper is not too bad in car. You need to remove the fan blade and water pump pulley. After that remove the bolts on the damer around the crank shaft.
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
  1. Spring/damper combination
    By Paul in NZ in forum 5 Series BMW
    Last Post: 02-21-2008, 01:40 AM
  2. Vibration Damper E34 525 td
    By Tony777 in forum 5 Series BMW
    Last Post: 03-24-2007, 02:04 PM
  3. Replies: 0
    Last Post: 06-07-2006, 01:58 PM
  4. Guibo & Vibration Damper
    By Kobe Diesel in forum 5 Series BMW
    Last Post: 03-08-2006, 03:39 PM
  5. E34 540 damper replacement???
    By ben wilamowski in forum 5 Series BMW
    Last Post: 11-03-2004, 06:58 PM
