Results 1 to 8 of 8
Thread: More Alternator Stuff
    Fogtown
    Default More Alternator Stuff
    I took apart my alternator today. The brushes are probably at their 5mm mark about now. They created a pretty big groove in the alternator.
    The alternator is a Valeo made one, the new voltage regulator that I received will not fit into the Valeo unit. I can't find a Valeo replacement regulator.
    FS: PBR Deluxe rear brake pads [new]
    O.C.
    Can you buy the brushes separtely????? Thats all you need I bet
    Fogtown
    Quote Originally Posted by aston_jag_tech
    BMA nor Autohausaz has them. I checked the brushes are different size from the Bosch ones.
    Aug 2005
    West Portland, OR
    I think my alternator is noisy, anyone have an audio clip by chance of a working alternator from and m20 or m30 car?
    EuroLux:. Private Detail
    Fogtown
    Is it a problem that there are groves on the contact?
    I never heard the alternator when engine is running. How to make an audio clip of that alternator running with engine running?
    For brushes, there are specialized companies which sell brushes only, any type, size you want.
    Contact one of these companies
    Custom Rebuilder of Starters, Alternators and Generators
    Doing it yourself? We sell parts.
    BUSHINGS, BEARINGS, BRUSHES, BRUSH SPRINGS, SOLENOIDS, ARMATURES, FIELDS, STATORS, ROTORS, GENERATOR KITS, STARTER KITS, VOLTAGE REGULATORS, THREW BOLTS, SHIFT FORKS, BRUSH HOLDERS AND MORE!
    http://stores.ebay.com/Triodiode-DC-...QQftidZ2QQtZkm
    http://search.ebay.com/search/search...p=1%26fsoo%3D1
    http://search.ebay.com/search/search...hes&category0=
    Apr 2005
    Canada
    Quote Originally Posted by Anton CH.
    Not really as long as those groves are not source of contact between the rotor segments (look at that visualy and if you can check with an ohm-meter if there is continuity or not between adjacent segments).
    Oldham, England
    Quote Originally Posted by Claude
    Bear in mind that carbon stuck in the groves may also conduct across the segments. I'd clean the groves out with a small screwdriver -careful not to scratch the com and dont go mad. And get any black (carbon) off segment faces with very fine glass paper, cleaning in the direction of rotation. Wipe down with meths. If it works great. If not, no harm done
  1. 540 e34 alternator
    By pheno in forum 5 Series BMW
    Last Post: 03-27-2008, 03:57 PM
  2. Alternator?
    By howdydee2003 in forum 5 Series BMW
    Last Post: 11-22-2005, 07:38 PM
  3. alternator stuff (pics)
    By skr in forum Electronics & Lights plus A/C
    Last Post: 09-23-2005, 07:11 AM
  4. alternator stuff (pics)
    By skr in forum 5 Series BMW
  5. Is there more than one alternator for the M30?
    By Jason in forum 5 Series BMW
    Last Post: 03-12-2005, 12:32 AM
