Results 1 to 8 of 8
Thread: this was wierd, any one else?
    Jun 2006
    southaven miss.
    Default this was wierd, any one else?
    my daughter was driving our 90 525, yesterday morning, it was about 20 degres out, she calls and says shes getting high temp coolant message and the car is going into the red, she pulld over right away, i was there in 10 min, there was some coolant spilled on the ground on the pass side and i could see some splattered on the right side of the rad and lower hose, i started up and temp was in the middle, no message, drove it home and around last 2 days, everything is fine, is it possible ice bockage?, never seen this before, thanks
    Dec 2006
    do you have antifreeze in your car? if so, what is the mixture?
    Nov 2006
    I would agree about a possible ice blockage somewhere, maybe preventing the coolant from circulating to/through the eater pump. How old is the coolant and what is the mixture?
    If the coolant wasn't frozen somewhere I'd look to the water pump first. If the impeller becomes loose on the shaft they work a little sometimes and not others.
    Don't fool around with an overheating M20. The crack cylinder heads like to crack.
    Nov 2004
    Gateshead,UK
    Ross has hit the nail bang on the head! The M20's are notorious for overheating problems if not looked after - get it sorted quick!
    Cheers,
    Shaun M
    Oldham, England
    Water pump gland? Coolant leaks onto the pulley/belts and sprays everywhere. Glad expands: no leak. For now.
    Jun 2006
    southaven miss.
    i jusr replaced the water pump this last summer with all new belts, im thinking i didnt put enough coolant in then and maybe the mixture was to low, its warming up to mid 60's tomorrow so i think i will re do the mixture, thanks
    Orlando, FL (Gainesville)
    air in the line? It happen to my sis' a month ago when it dropped below freezing. Somehow a huge air pocket formed and was reaking havoc
  1. Wierd Mis-fire
    By Washburn in forum 5 Series BMW
    Last Post: 01-20-2009, 11:03 AM
  2. Wierd sound when turning off
    Last Post: 04-21-2008, 05:53 PM
  3. Wierd problem
    By colamangr in forum 5 Series BMW
    Last Post: 09-17-2006, 01:56 PM
  4. This is wierd....20 MPH shimmy?
    By DanDombrowski in forum 5 Series BMW
    Last Post: 02-26-2006, 03:40 PM
  5. Wierd Electrical Stuff
    By The Melmaan in forum 5 Series BMW
    Last Post: 03-06-2005, 08:45 AM
