the m30b34 is slightly less powerful then the m30b35 from a e34 but it's close enough, you will need the harness computer and brackets from a e34/32, i can't remember if all of the holes are in the right side of the block for the engine mount on the b34, sort of like when i put a b35 in my 81 633 i had to make a plate because then eliminated a couple of the holes in the later block
i made a 1/4" plate that went to some other holes near the mount (one or two of the holes were in the right position so i use that to position the mount) and threaded the plate and bolted the mount to the plate
as for a tranny a 5 speed will work between the e34 and e28 but you will need the driveshaft, crossmember and shifter assembly
