Results 1 to 10 of 16
Thread: Pull engine from above or drop it from below?
    PA
    Default Pull engine from above or drop it from below?
    Hey guys - preparing for heart surgery on my poor car. Should I be focusing on removing the engine conventionally from the top with a load-leveler and a cherry picker or, since I have the car on a lift, should I try and drop the motor from below with the cross member and all? Trying to do this the best way possible.
    Thanks all.
    Wellington,New Zealand
    how do you drop it from below....would still require the support from above wouldnt it? have always thought it would be a whole lot easier if grills,radiator,and all the front is removed,then its relatively easy to pull motoer and trans together??...just my 2 c worth
    PA
    Well I imagine I could drop the thing from below by dropping the whole front subframe - we do this a lot on VW/Audi/Porsches, I just haven't spent enough time under the E34 lately to recall if its easier or not.
    The trans and motor come out just fine through the top with a load leveler its just a pain with the car on a lift because the cherry picker doesn't go too too high.
    The 3rd option you mention I forgot to ask about - does the radiator support come off easily? Is it welded in? If so, I could drill out the tack welds and bolt it back in when done - my front end needs considerable reconstruction considering the size of the intercooler I am going to run. I do like the sound of this best so far, but it might be a project itself just getting the front end apart!
    i always take em out the top, the tranny will come with it just fine too, front drive volvos are the only ones i take out the bottom, the core support unbolts
    you don't gotta unbolt the core support to pull the engine
    PA
    Awesome - sounds like I'll pull it from the top. One question though - when I pull motors (e36/e46) I wrapped a chain around the rear exhaust manifold and one in the eye of the front pull point. However, I am not going to lift my engine by the freshly coated and welded turbo manifold, so what do you do to support/lift the rear?
    Core support == rad support? I might remove it just because it'll be easier to mount my radiator further backward as I've got to fit my giant intercooler.
    core = rad, i always hook to the block lift point by the starter as i have a chain that fits the hole, you can use one of those horse shoe shaped shackles with the screw in pin in that hole so you can hook in with a normal sized chain
    PA
    **** you're right I forgot about that lift hole! It's been a while I need to get rowdy with my E34 - just a few more parts to go!
    Jon, Who's your interior decorator?
    I have a cherry picker and am gonna pull the M30 engine out while leaving the tranny in.
    Questions:
    How best to remove the three bolts on the torque converter?
    How best to remove the top 3 or 4 bolts that hold the bell housing to the back of the engine?
    Dash01
    '90 535ia 272K miles
    PA
    Take the trans with the motor, trust me.
  1. Drop it like its hot
    By ArnZ! in forum 5 Series BMW
    Last Post: 09-24-2009, 10:04 PM
  2. big drop off in mpg
    Last Post: 05-05-2006, 08:02 AM
  3. Volt drop vs fuel pressure drop/stumble
    Last Post: 04-24-2006, 07:06 AM
  4. So how much drop?
    By Island530i in forum 5 Series BMW
    Last Post: 02-09-2006, 03:05 PM
  5. M30 Engine pull question
    Last Post: 06-30-2005, 09:04 PM
