Do you really need distilled water? Is tap water not good enough?
if i were to drain out the whole engine, how many litres of distilled water do i need to fill it back up (assuming i don't use coolant)?
'01 540it, 6/01
'03 325i 5 speed, 9/02
'10 535ix. 9/09
'10 mini 6 speed
'15 mini countryman 6 speed
distilled water is like, 1 dollar a gallon.
Simple test: If your kettle is full of nasty chalky deposits thats what the inside of your rad and block will look like if you use itOriginally Posted by yaofeng
about 2 gallons give or take a little, i run tap water the green **** takes care of any corrosive property's that may be present, that is after all half of the point of antifreeze
