Originally Posted by
ThoreauHD
If you are talking about the bavauto coils without resisters, you will need to get the wiring harness as well. All the rest like bremi/bosch/etc. are OE and you can keep the harness. The ECU is a separate issue. Having more spark/less resistance doesn't depend on the ECU.
If you haven't already though, you should consider getting the conforti or EAT ecu chip. There is nothing to tune. It's either there or it ain't. Once you change your octane to 93, install the ecu chip, and replace the aging coils and harness, it will run much better. I would also recommend denso iridium for the spark plugs. And just in case it's been ignored, make sure you are using synthetic oil in the transmission/differential and engine. I opt for redline and amsoil, respectively. Your mpg will improve as will your responsiveness/initial torque. Good luck.
