Bart, what's busted dude?
Here's a couple points to consider based on the couple times I've done this:
- I haven't pulled a motor with an auto so just factor this in but have done a manual several times...soo...apply as helpful.
- For your tranny bolts, get them from under the car. You can get more space by removing any aft tranny mounts and setting the back of the tranny on the cross support. This will give you both space and angle.
- A good trick from Martin to help with the tranny torx bolts - put a little valve lapping compound in the torx socket. Really helps with the grip on the bolt. And yes, get a batch of long extensions and flex drives.
- Get a tipper for your engine hoist if you don't already have one. You'll need it to angle the motor in/out etc.
- Watch your injector harness especially in the cold. It will need to be pushed back out of the way. It's a PITA.
- I found the simplest plan was to pull the motor and install the motor with as many accessories on it as possible. You should be able to leave on the manifolds, fuel rails, filter canisters, etc. Swapping this stuff while the engine in on a stand or hoist is much easier than doing it bent over in the bay.
- Expect you'll need to drop you exhaust system. Might be easier to drop the whole thing vs. disconnecting at the cat back connection. While you won't need it out to pull the motor, I think you'll certainly need it out when you install.
- To get a little more room at the front of the engine prior to pulling / installing, remove the water pump.
- All those little plastic electric connectors will be brittle. Take care with them. A heat gun may be a good idea to help warm things up a bit so you don't snap them all.
- Still have your factory sound installation pad? Get a boat load of new clips as you'll bust a bunch removing it.
If I can think of any more tips, I'll post them.
Cheers!
Jeff
Bellevue WA
86 Porsche 951 - Track Toy
