Results 1 to 10 of 14
Thread: Can't Open Driver's Door from Inside
    Los Angeles
    Default Can't Open Driver's Door from Inside
    I guess I have been hitting the gym too hard lately.....
    When I tried to get out of my car last night, the interior door handle gave way - no resistance any more, and the door doesn't open. It feels as though something gave way in the interior of the door panel, almost like a rubber band snapping. The door still opens fine from the outside.
    I'll probably bring it by the shop this weekend (and will open the door from the outside for the time being), but I was wondering if anyone has experienced this before.
    thanks,
    db
    dave b
    93 525i
    156k +
    Dec 2006
    there is rod with a hook on the inside of the door that is attached to the door latch. This is what connects your door handle to the latch. Remove the door panel and you can reconnect the hook.
    Los Angeles
    Quote Originally Posted by repenttokyo
    That's what it feels like happened. How difficult is it to remove the panel? Harder or easier than replacing a microfilter.......
    thanks!
    db
    dave b
    93 525i
    156k +
    Dec 2006
    Quote Originally Posted by dave b
    thanks!
    db
    I actually replaced the microfilter in september, coincidentally - so in comparison, taking off the door panel is much easier, it's really just a matter of removing the screws, and then pulling the panel up and off. I also had to remove it when my window fell off the guides in the spring, it gets easier each time you do it - but it's really not a hassle at all.
    either the rubber grommet that holds the hook in the handle crumbled dumping the hook or the cable snapped (no rod, bicycle looken cable)
    San Jose, Ca.
    Default Door Panel Removal
    The write up on the bmwe34.net site is not clear on the screw behind the interior door handle. You must remove the small plastic cover by prying it off with a small screwdriver and then remove the screw.
    The screw is shown in the first picture but no mention is made of it.
    1995 540iA - 1988 535i 5 Speed
    1980 528i 5 Speed - 1980 528iA (Sold)
    Los Angeles
    I'm thinking a little here. Are the cables and grommets the same in all the doors? I might just remove one from the rear passenger seats. They never get used anyways. Could save a trip to BMA...
    db
    dave b
    93 525i
    156k +
    Nov 2006
    Maryland
    i don't know about the cables but RealOEM.com is your best friend. I lost one of the rubber grommets for my pass. door and just used layers or vinyl tape as a substitute and it worked! lol
    i can't remember if they are the same length, some are shorter
    db
    Nov 2006
    Maryland
  1. Driver's door open warning
    Last Post: 06-14-2010, 05:26 AM
  2. Replies: 10
    Last Post: 09-11-2006, 03:21 PM
  3. Hood Open, Door Open, Trunklid Open
    By MDT in forum 5 Series BMW
    Last Post: 07-20-2005, 02:25 PM
  4. Can't open driver's door (long, please help!)
    By Mr Project in forum 5 Series BMW
    Last Post: 04-20-2005, 11:17 PM
