True. I've seen wet carpet do this. After 12+ years, lots of nastiness gets under the seats.Originally Posted by shogun
My passenger seat stopped working suddenly the other day. Now I've had this problem before and was a simple fuse issue.
I checked the fuses under the rear seat and they are all good, does anyone have some suggestions? Maybe something i'm not thinking about?
Check the connectors for corrosion. I once had that on my car, it was the relay under the rear seat for passenger seat (location refers to E32).
Just switched both relais between right and left seat, and the other side was dead, installed new relay, worked perfect.
Originally Posted by Kalevera
Where is this relay, in the back of the seat or under the seat?
I had to passengers, in the car one in the seat and one behind it, all of a sudden the seat stop moving.
May be the adjusting seat switch (bad or intermittent contact), but usually that start for one of the seat directions (forward, backward, upward...) but not for all of them the same time in such a case i would also suspect fuses or bad connector or bad cablingOriginally Posted by EngPhys09
