Results 1 to 10 of 12
Thread: fire under rear seat- corroded contacts
    Bay Area, CA
    Has this problem happen to any other e34 or similar generation BMW owners?
    Greg Mannino
    Aug 2005
    West Portland, OR
    omg!!! :-O!!!!
    EuroLux:. Private Detail
    That must have stunk a bit. I wonder if they'll get the smell out of cabin easily.
    Helped an e32 owner find an LKM. Went to 'instal' it for him and found the remnants of a previous fire/melting episode. LKM worked fine, but I gave him no guarantess his fuse box and everything in it would last much longer.............
    Dave M
    1 comment on BB, maybe the electric experts here can answer:
    The rear window heater fuse may have smthg to do with the fire in Pete's car, after I saw the way the fuse body plastic melted for the rear window heater (fuse 46) yesterday. Any suggestion of what better to do with that fuse? like reducing the rating if the heater coil doesn't draw near 30Amp? or remount that fuse away from other fuses and use a different kind of fuse like the glass tube type? I think there is a period of time where the fuse turned half melted due to usage, and had increased resistant. Thus the fuse element would start to heat up and either melt, or ignite the surrounding plastic.
    Patrick C 88 750 159K
    Bay Area, CA
    Decrease to 25 amps should be an easy fix.
    Greg Mannino
    Nov 2006
    That's pretty nasty! But these cars seem to have a problem with the defroster fuses.
    In my '90 525im, the defroster fuse had blown pretty obviously; replacing it made the def work fine again. IN my '90 750iL, the defroster fuse had melted pretty good, but a new fuse made it all work fine again.
    vince
    Apr 2005
    Canada
    No specific solution but the following info may help your thinking
    http://www.circuitprotection.ca/fuseology.html
    Any fuse should "fail safe" it suppose that it's holder is a good one, the contacts also good and the surronding well ventilated.
    Mar 2004
    NJ
    So what's the remedy? Remove everything periodically and clean the contacts? Are the contacts from adjacent circuits fusing together or something??
    T·O·R·O·N·T·O
    Well, here's what mine looked like...
    http://www.bimmer.info/forum/showthread.php?t=35869
  1. Coolant level float contacts.....
    By JD525IA in forum 5 Series BMW
    Last Post: 06-18-2009, 10:05 PM
  2. Contacts & Friends
    Last Post: 11-30-2008, 09:24 AM
  3. Rear seat
    Last Post: 08-04-2008, 01:39 PM
  4. Replies: 4
    Last Post: 01-16-2006, 09:00 PM
  5. ICV contacts
    By mulebiscuit in forum 5 Series BMW
    Last Post: 11-16-2005, 03:51 PM
