Results 1 to 9 of 9
Thread: Lud squealing / sometimes short grinding sound inside my dash
    Dec 2006
    Default Lud squealing / sometimes short grinding sound inside my dash
    It happens when I hear use the fan with my heater - most of the time it's a constant squealing sound. What can I do about this? Does the fan need to be lubricated? How hard is it to get at the part that is squealing?
    Apr 2005
    West of Cinci, OH
    Quote Originally Posted by repenttokyo
    It's likely the fan motor, open the closing panel on the firewall behind the motor, then remove the cover from the fan housing and either lubricate the bearings or replace the motor. I'd suspect the motor is about done, as the bearings are oil-impregnated bronze sleeve bearings that have likely worn out.
    Dec 2006
    Quote Originally Posted by icesoft
    thank you for the reply. Is it difficult to replace the fan motor? It is winter here now and my driveway repairs have become limited to fairly easy jobs. Is there anything in the way on the firewall?
    Nov 2004
    Gateshead,UK
    you might be lucky and just have something stuck in the fan blower. I sometimes get bits of leaves in there so it makes a squealing sound. I whack the blower onto full and within 10 seconds the piece of debris flies out, usually through the centre dash vents.
    HTH,
    Shaun M
    Reading, UK
    Is the squealing coming from the front of the dash or by the gear shifter?
    Mine keeps making the squealing noise from by the gearshifter, getting to the point where I cant 'adjust' it any more and am going to have to get a new sensor fan :/
    Dec 2006
    Quote Originally Posted by E34-520iSE
    HTH,
    Shaun M
    i've tried that - so far, nothing Is there any way to open it up and clean it?
    Dec 2006
    Quote Originally Posted by Ferret
    It's from the front of the dash.
    Reading, UK
    May be a badly worded question, I meant to say coming from behind the heater controls or the actual blower fan area. Ambiguous question!
    Dec 2006
    It's from the blower fan area, towards the windshield
  1. grinding sound when coasting in gear
    By BigTed00 in forum 5 Series BMW
    Last Post: 01-23-2007, 03:29 PM
  2. squealing sound at the driveshaft
    By grave77 in forum 8 Series BMW
    Last Post: 01-03-2007, 05:11 PM
  3. grinding sound when car starts / cold
    By gymkata in forum 5 Series BMW
    Last Post: 12-05-2006, 08:58 PM
  4. Sound inside dash when cornering or accelerating
    By puppypilgrim in forum 5 Series BMW
    Last Post: 10-30-2006, 02:22 PM
  5. Suggestions for grinding sound in clutch
    By Hamido in forum 5 Series BMW
    Last Post: 04-05-2004, 06:50 AM
