Results 1 to 5 of 5
Thread: Rear brakes click
    Default Rear brakes click
    Hello everyone,
    Recently I've noticed that my car developed a new sound. When I apply the brakes, sometimes I'll hear a pretty loud metallic "click" from the left rear brake. Brakes work normally and I've inspected the rear brakes for loose bolts. I also added some lube to the areas where the pads contact the carrier. I've heard of caliper bushings being mentioned in other threads and I'm wondering if this refers to the guide bushings? If these are worn, do they cause a sound? What could cause this sort of noise other than that?
    Thanks in advance.
    Oldham, England
    Quote Originally Posted by Rus
    Hello everyone,
    Thanks in advance.
    If the pads are loose in the guides, they could move a tiny bit and give a click when they hit the 'stop'. My experience is actually the reverse-they tighten up due to rust/brake dust etc and I've even had to file the backing on new ones as they arent exactly made to fine tolerances. The pins on which the caliper slides can wear but they would have to be in a dreadful state to make the sort of noise you mention
    Mar 2007
    Liverpool UK
    This suggestion is in no way meant to insult your intelligence but you haven't lost one of the anti-rattle clips and not noticed have you? The reason I ask is that it happened to me on my e46...
    No offense taken. The clips were one of the first items I thought of too, but they're in place as they should be. I'm probably going to pull the brakes apart sometime around christmas and clean/lube them. They've not been touched for about two years since I redid them with new rotors and pads. Thanks for the input guys
    Mar 2007
    Liverpool UK
    I thought you would have checked these first but sometimes the most obvious things can be missed more easily! (Prob just me that ) If you find out what it was let us know!
  1. rear brakes not working
    By aquapool in forum 5 Series BMW
    Last Post: 03-03-2009, 04:09 PM
  2. Smoking rear brakes...literally. Need help with causes.
    By bimerguycw in forum 5 Series BMW
    Last Post: 10-19-2007, 11:37 PM
  3. question on rear brakes
    By ejhiggins in forum 5 Series BMW
    Last Post: 01-13-2005, 11:38 PM
  4. E32 750 rear brakes on E34 Bruno??
    Last Post: 07-02-2004, 01:01 PM
  5. Rear brakes locking up
    By mjfeeney4 in forum 5 Series BMW
    Last Post: 02-28-2004, 07:50 AM
