Originally Posted by
BMWDriver
Here's part of a post I had found on bimmerforums:
Since so many have commented on bad coolant sensors, here's a tip:
The coolant sensors aren't going bad. The connection between the sensor and the wireing harness is. Next time you change it, clean (and i mean wire brush clean) the contacts on the sensor plug. Then, coat the prongs in dielectric grease to ensure a good connection.
I did this a year ago after constant coolant sensor replacements and I'm happy to report it hasn't been an issue since.
Ditto - I used pliers to squeeze the pins a little together so the fitting was tight.... Of course I did this after replacing the sensor and NOT fixing the problem (would randomly come on)
1995 BMW 525i w/139K miles, EAT Chip - (Gone)
07 525i 22K, 07 328xi (41K)
1982 Mazda RX-7 w/147K miles (Back again!)
